Gizmo constantly gets in the way while editing
How do I select vertices when transform gizmo is in the way? In Blender it was not a problem, because you either don't use gizmo at all or you select with RMB and manipulate gizmo with LMB. In Maya I can't perform transformations without gizmo. Making the gizmo smaller is not a solution.
mspeer
Hi!
In Tool Settings, try "Tweak Mode".
Now the gizmo is gone and I can move vertices only along already existing geometry, that's not what I'm looking for. I just want to be able to select geometry without gizmo getting in the way.
mspeer
Hi!
"I can move vertices only along already existing geometry"
- You should be able to move a vertex in every direction, here it works.
The only other option is to use marquee selection.
"- You should be able to move a vertex in every direction, here it works."
How? What do I click?
mspeer
Hi!
Try with visible manipulator first, middle-mouse click on the axes / direction, but outside of the handle.
(shift click to change axis).
It works the same if the manipulator is invisible.
Ok, I get it now. I have to hold shift and MMB and drag.
