Exporting wireframe or grid view of the model
zardtomcat
Message 1 of 11
zardtomcat
I have a model and I like to export in such as way that the model looks like below.
I can kind of look at the wireframe view of the model in Maya but cant export that view. Does anybody know how to do this?
Replies (10)
Message 3 of 11
zardtomcat
Thanks, I am new to the forum. I tried to remove it but had no luck.
Anyways, if you know of a solution regarding exporting, would be great to share it.
Message 4 of 11
n8skow
It looks like you are trying to render the wireframe - not 'export' it.
In that case - you can attach a renderable object to the wireframe - like a neon effect from PaintFX.
Message 5 of 11
zardtomcat
Thanks, I have a couple of questions though. As a non-expert in paint effects
1- would it give me the effect I need (I have already subdivided my model to the required level).
2 - If it does, how do I do it ( I am not an expert in paint effects). I have to apply the effect just to the mesh lines not the surfaces.
Message 6 of 11
zardtomcat
Any suggestions as how to do this?
Message 7 of 11
damaggio
Sorry but there isn't much information here to recommend a workflow.
No pictures of the model.
We don't know the Maya version nor the renderer used.
Message 8 of 11
zardtomcat
I  use Maya 2024.1 for this work. I didnt use any materials.
I simply created a cube from the modelling section. Using sub division and beveling , I modified it and changed the wireframe colour. I then exported it. See image.
I know that this can be done in blender, but I dont want to use multiple tools to do it, so any help on how to do it in Maya is much appreciated.
Message 9 of 11
zardtomcat
Here it is.
Message 10 of 11
damaggio
What you need to do then is render the image with an Arnold wireframe shader.
Message 11 of 11
zardtomcat
Thanks. I checked options under Arnold and there are no wireframe shaders listed. Do I need to import a plugin for this or am I looking at the wrong place?
