Exporting solid UV shells
HeavyMetalFox
Message 1 of 19
HeavyMetalFox
The UV snapshot options in May are very limited, I am looking for a way to be able to export "solid" UV shells where they have on color inside of them (no wireframe) for 3d painting purposes, is there  a way to do that?
Replies (18)
Message 2 of 19
mihirsbcc
What you mean by Solid UV shells?
Message 3 of 19
HeavyMetalFox
something like this:
Message 4 of 19
mihirsbcc
Since you are 3d printing, how UV matters for print?
Message 5 of 19
mihirsbcc
there might be a script somewhere. default Maya i don't think it is there.
Message 6 of 19
mihirsbcc
However you can make each shell have a different color. But when you export UV snapshot the wire frame will be on top of the color.UVShell_col.JPG
Message 7 of 19
HeavyMetalFox
how can I did you assign the colors to the shells?
And were you able to export the snapshot with the colors?
Message 8 of 19
mihirsbcc
well color is in the option there. but i did not export the color. I may try later
multicolor-shellmulticolor-shell
Message 9 of 19
HeavyMetalFox
ok got ya.
but couldn't export the colors.
Message 10 of 19
mihirsbcc
You may look for some UV scripts free at highend3d.com Maya scripts and plugins. Last time I had a app ROADKILL for Maya. I think that one does bi default.  If I were you then I will look for 3rd party free scripts.
Message 11 of 19
mspeer
Hi!
@HeavyMetalFox  and @mihirsbcc
You can't export colors with the UV Snapshot Tool.
The only option (besides taking a screenshot) is to bake the colors to a texture, for example by using
Arnold -> Utilities -> Render Selection to Textures (with Extend Edges disabled), this does produce the output as requested.
Message 12 of 19
mihirsbcc
screen shots is my usual path.
Message 13 of 19
HeavyMetalFox
when I do that I am getting a transparent EXR texture.
Can you please post a video showing your workflow?
Message 14 of 19
mspeer
Hi!
There will be an alpha information written with white where there is something and black where there is no color information. You could even directly use the alpha/transparency information, but when you skip this you get the color from the object + black (empty).
There are just 2 steps:
1. Select the object.
2. Render Selection to Texture
Please provide a scene-file, one step before you use Render Selection to Texture.
Message 15 of 19
HeavyMetalFox
tried with not much success
Message 16 of 19
mspeer
Hi!
This works, I am 100% sure.
If it does not work for you, please provide the Maya scene-file and your EXR image file.
Message 17 of 19
mspeer
Hi!
Here 2 screenshots, one before baking the texture and one after baking, so this seems to be exactly what you requested.
Message 18 of 19
HeavyMetalFox
Great and thanks alot!
Now is there a way to make the wireframe show?
I am doing this because I need this map in Unity and the UV snapshot tool in Maya generates jagged lines (even with anti AA turned on)
Message 19 of 19
HeavyMetalFox
bump
