Export multiple models as separate .obj quickly and GoZ
Is there a quick way to export multiple models as separate .obj files?
My intended purpose for this is to bring them into zBrush. The GoZ button will not work as it should using an academic Maya 2018 version. This error occurs when trying to select all models and then use the button:
// Warning: file: C:/Users/Public/Pixologic/GoZApps/Maya/GoZBrushFromMaya.mel line 472: fopen: unable to open file "C:\Users\Public\Pixologic\GoZProjects\Default\Modular_Pieces|Pillar_1.ztn" for mode "w".
Exporting model individually is tedious and there seems to be no way of separating the models from each other if they are exported and imported as a single .obj file in zBrush.
https://www.artstation.com/jamesfurler/blog/9m4L/batch-obj-exporter-for-maya-released
Works great and I was able to export 275 different meshes in about 2 seconds.
