Export Alembic Failed
Hello, Today i had a problem with exporting a group of objects in alembic and i don't understand why.
When i export i ve this message :
// Error: Alembic Exception encountered: OTypedScalarProperty::init() ERROR: EXCEPTION: Already have a property named: .facesExclusive
Two days ago it works 🙂
Thx 🙂
mael.marku
Observer
Observer
Up
I'm getting a similar problem, trying to export a bullet rigid set
The sim works, but when exporting it says an object is already named (insert one of the set's object name)
But like...the object itself has the same name that...it has...If i change it to like "thingy_01", then it says there's already an object named thingy_01 when I try to export the set
If anyone has an idea of what the problem could be, it'd be much appreciated
fadamPCDW2
Community Visitor
Community Visitor
Bumping this thread as I'm dealing with the same issue while exporting Alembic. Any help would be appreciated.
jonah.newton
Replying here in case it helps someone in the future.
This occurs when exporting a transform to Alembic that has multiple shapes inside it with different materials assigned.
E.g.
To fix, just make sure all shapes inside a single transform have the same material assigned.
