Announcements
Edge won't loop
Edge won't loop
Edge won't loop
Hello, I'm new to Maya and modeling. I'm trying to model a knife and I got some edge loop problem. I couldn't figure out what causes the problem. I also attached my scene file. Thank you in advance.
https://drive.google.com/file/d/1SZa6ZO5yeeuz9TsSj0sXzmbRQkep8S8X/view?usp=sharing
mspeer
Hi!
Sorry, I can't see any problem.
If the issue is about the selection of the edge loop, this works totally correct, based on your topology.
It select all edges on a continues path and then steps where the path ends (and there is no further edge straight ahead, only left or right).
Just use Shift selection to add further edges.
Thanks!
