Announcements
AREA content is being relocated to the Autodesk Community M&E Hub and Gallery. Notifications may be intermittently unavailable 10–12 November. Learn more HERE.
edge flow bug ?
edge flow bug ?
vladtofan
edge flow bug ?
vladtofan
Hey.
    Is there a reason why edit edge flow (0,8 setting as shown here https://www.youtube.com/watch?v=OFfAtnnfCOw ) is inconsistent with multi-cut with edge flow at the same 0.8 setting ?
    And why 0.8 and not 1 for perfect edge flow distribution ?
Thx
vladtofan
@mspeer  @sean.heasley  do you guys know the answer at this pls ?
mspeer
Hi!
I don't see a difference for Multi-Cut and Edge Flow.
Also the assumption that 0.8 leads to a round surface is not correct.
This is only true for the particular case at the end of the video. Test this with other values like 4 subdivisions or 60 subdivisions for the cylinder and you get other values.
1. A perfect edge flow does not mean it's circular (think about waves or a sinus curve)
2. There is only a limited amount of information available for extrapolation, so the result can't be perfect.
If you want clearly defined surfaces, please use Nurbs.
