Detach/Extract multiple objects/shells as 1 object
transistor06
transistor06
Hello, I'm looking for something in Maya that behaves like the 'Detach' button in 3DS Max.
For example,
If I have 1 character object that has 1 sword attached, so that they both are 1 object - I want to detach the sword, so the result will be 2 objects (character and sword).
However, the sword is made of 3 separate smaller objects (Maya people call them 'shells' if I'm not mistaken).
1 - the blade
2 - the hilt
3 - the handle
So, when I select all 3 objects of the sword, and press 'Extract' these are all separated into different objects, and the result is 4 total objects.  This means I have to take an extra step to 'Combine' the 3 sword objects into 1.  Is this the correct way to do it?
I would prefer a way to separate the sword in one step.  Is that possible?
Thank you for your time.
Christoph_Schaedl
duplicate the char with sword. delete sword. delete char.
https://linktr.ee/cg_oglu
transistor06
Gee.  Thanks.
lauri_barnhart
Hi @transistor06,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Lauri | Community Manager
