Created curves not visible.
lightstream
Message 1 of 13
lightstream
For some reason newly created curves are not showing up in the viewport. I did a polygon edge conversion and the curve is visible in the Outliner, but not in the viewport. So I tried creating an EP Curve using the snap to vertex option and, again, nothing is visible in the viewport only in the Outliner. Obviously, I've done this before so why it's not showing up now, is baffling. I tried restarting and that has not helped. Has this happened to anyone else? Any thoughts on how I can fix this? I would apprecaite any help.
Maya 2016 MacOS
Replies (12)
Message 2 of 13
mspeer
Hi!
Check Viewport menu:
Show -> Nurbs Curves
Message 3 of 13
lightstream
Thanks! That was it. Don't know how that got turned off in the first place. Thanks again!
Message 4 of 13
artofjukin
Community Visitor
Community Visitor
whats a viewport menu? cant find it . my circle's not showing 😞
Message 6 of 13
mihirsbcc
The best way to direct to newbies to docs.
Message 7 of 13
mihirsbcc
Here is a cool tool from the Help Menu> Find.Find Menu from HelpFind Menu from Help
Message 8 of 13
nicholaus.downer
Thank You!
Message 9 of 13
thnx
Message 10 of 13
abars51099
I tried this, but I still can't see the curves
Message 11 of 13
natashamrPBRXZ
viewport is the little bar that has view and show and renderer panels etc 🙂 this photo should help
Message 12 of 13
lightstream
Thanks for the reply. This happened so long ago, I forget how it was solved.
Message 13 of 13
tiizzzzz26
Community Visitor
Community Visitor
Thanks for the solution
