Copy\Paste UV Shell
Copy\Paste UV Shell
slava.lobanov.1990
Message 1 of 1
Copy\Paste UV Shell
slava.lobanov.1990
Hi. How to copy and paste uv parts correctly in Maya?
In 3ds max, this is done with these commands. I select the desired part, press copy, select other parts, press paste. All parts fit into 1 position and, accordingly, they can be attached to 1 part of the texture. In Maya, if you do the same, then all chats are cut into single polygons.
  • UV
Replies (0)
