Announcements
Combine NURBS objects?
neoxcorex
neoxcorex
How can I combine nurbs objects together.
I've tried using the Attach Surfaces Options, but this causes distortion between two nurbs objects.
For example, If i have two spheres overlapping one another, how could I combine as one object.
I'm pretty sure I was able to combine two nurbs objects together using the Combine option under Mesh (Polygons).
Any help would be appreciated.
Anifex09
I think the tool you are looking for is boolean - select your two NURB surfaces - goto Edit NURBS - Booleans - Union Tool
neoxcorex
I'm trying to make multiple nurbs objects live so I can use the Quad Draw tool on them.
I guess my real questions is, is it possible to make multiple nurbs objects live at one time?
halfstone
Only one NURBS object can be made live at any one time.  If you just want to set them up for Quad Draw, I'd suggest converting them to Polygons, combining them into one mesh and (if they line up OK) merging the verts.  I don't think you need to do that last step for Quad Draw.
When converting the NURBS to polygons, use the following options:
Type: Quads
Tessellation method: General
U Type: Per Span # of isoparams
Number U: 1
V Type: Per span # of isoparams
Number V: 1
Turn "Chord Height" and "Chord Height Ratio" both off.
This will give you polygon objects with a 1:1 ratio of NURBS spans to polygon edges.  If you want a denser, or smoother polygon, adust the "Number U" and "Number V".
For attaching NURBS surfaces to each other, there are some rules which, if you don't follow them, you'll get some pretty interesting, but useless, distortions.   I made a video explaining NURBS parameterization and attaching a while ago - I just uploaded it to YouTube, here
