cant import obj Models into Maya 2017 due to the error code below
I have tried to import a obj File that i recieved from a friend but the only thing that happens is the following error code
// Error: file: /Applications/Autodesk/maya2017/Maya.app/Contents/scripts/others/hikCharacterControlsUI.mel line 329: Object 'hikCharacterList|OptionMenu' not found.
I dont really know what to do. I already checked the obj file and it seems fine, through the preview app on Mac OS i can get a rough 3D view of the model which worked perfectly fine.
mspeer
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2017 to something like prefs_backup, or to reset everything, the folder 2017 to 2017_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
