Can't Import SVG To Maya
mirza8hamza
mirza8hamza
Hi.
I Can't seem to be able to add Any SVG files. I tried importing from Adobe Illustrator and Affinity Designer and also tried pasting the curves directly into Maya. I even tried re-installing Maya, but it still didn't work. The error that is more repetitive is "Can't perform polySoftEdge1 on selection".
Below are the errors I've been getting. (I've also attached a txt file with complete Script Editor errors.)
My PC specs:
OS : Windows 10
RAM : 16 GB
CPU : Intel Core-i7 3770 3.4 GHz
GPU : AMD Radeon R7 200 Series
Mainboard : Asus H61M-K
HDD : 1 TB
I'd appreciate any working solution.
Thanks.
Hamza Mirza
hey there! have you found any solutions to your problem? I have the exact same issue..
mike.marshall698AD
Community Visitor
Community Visitor
I was having the same problem, but I figured it out after a lot of testing. Maya doesn't like strokes. So either create a solid shape or "outline stroke" in Illustrator or "expand" stroke in Affinity Designer.
Hi, i have the same problem, but diferent.
Well, in my case only can submit a svg from 3D section on Windows, if i try select a svg file in other folder always aparece a error notification.
I don't know why this happens, but that's what I could find after doing several tests. XD
