Can't delete an object
christophe_david
christophe_david
I'm having an issue with an object that gives me an error: showEditor.mel line 4390: Invalid object name: |:Back_Wall_L_f_0:125]
I managed to duplicate it and use the duplicate normally but I can't seem to be able to delete the main one. Also when that object is selected I pretty much can't do anything with Maya unless I select another object.
If anyone has an idea, that would be great.
Thanks a lot
trs_andre
Hi!
I found kind of a similar problem: https://forums.autodesk.com/t5/maya-forum/can-t-delete-an-object-error-line-quot-no-object-matches-n...
"Open Hypergraph Connections (Window > General Editors > Hypergraph Connections), find the broken object, select it in the Hypergraph Connections window and delete it."
Does this help in your case?
André Moreira
Game Developer / Technical Artist
LinkedIn
christophe_david
Soooo, weird thing, I didn't touch anything but when I opened my project today, the object was back to normal, I can modify or delete it normally.
I have no clue what happened, some kind of a glitch I suppose, so if that happens to anyone, save your project and restart Maya, it might do the trick.
Thanks for the help.
crissgarcia189
Community Visitor
Community Visitor
Thanks bro, great help.
