bug in maya 2026 when after rendering
jxsb6
jxsb6
bug in maya 2026 when after rendering,
please see my file,and test rendering again
my file
nelsoncruz
@jxsb6 You have the pPlane2 scale attributes keyed.  You are clicking the render sequence button from he shelf  an so after rendering the first frame Maya will move to the next frame based on the keys being set which are 1,1,1 for scale.  If your not expecting to animate the scale of the mesh, you can remove the keys from the xyz channel by right clicking on each and breaking the connection in the attribute editor.
Nelson Cruz
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
jxsb6
i dont understand how to remove the keys, can you explain with video tutorial?
nelsoncruz
Here is a quick video I put together showing a couple of ways of removing the set key that is contributing to your issue.
Nelson Cruz
jxsb6
thank you very much for your explanations
