Break the link between objects
I am so confused by this problem. So I am at very beginning. I made two polyplane and I used the lambert material to import the images in. I used the  uv planar to adjust the image positions. Every time I moved one of them, the other one will follow the moving. Not only basic move, It stretched.
hamsterHamster
Not clear what is moving when and how, sorry.
Can't you use built-in image planes? Like, in the Front view menu View>ImagePlane>ImportImage..  Ensure that Display: in All Views is enabled. Placement extras section for repositioning and resizing to match other planes.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Thank you for helping me I will try this first.
