01:28 PM
- Mute
- Permalink
- Report
Hello Autodesk community,
I have a problem with the booleans commands, if I apply it to very simple shapes such as a cylinder and a sphere or two cylinders it works perfect. But if my surfaces are a bit more complex (for example a lofted surface) they produce a number of different errors:
-many times one of the objects dissapear
-it shows an error: "operation has history, inputs are not detected" (I attach screenshot)
-it only trims a part of the object
it also makes the program crash.
Any advise?
Is there any other way to merge surfaces that is not using the boolean operations?
Thanks!
