Boolean HELL!
Boolean HELL!
vfxronin
Message 1 of 12
Boolean HELL!
vfxronin
hey,
So im not going to beat around the bush about boolean in maya but its just Horrible! when you compare it to Modo, cinema 4d!
Speticall we we all saw this at Siggraph!
giphy
Can anyone Recommend a 3d part plugin that allow me to do a similar or a Boolean with large poly count that doesn't crash maya.
thakns
Sorry to be a bit mean about this! but its relllllyyyyy frustrating.
Replies (11)
Message 2 of 12
mspeer
Hi!
1. Example from Maya (without any plug-in):
 This also works with a higher Polygon Count (as long as the mesh is "clean").
2. Plug-in "Bool" from Mainframe:
https://www.mainframe.co.uk/products/bool
Message 3 of 12
vfxronin
thank you @mspeer for pointing out the Bool tool, i really love what Mainframe dose for maya it amazing.
I should have pointed out that Modo and cinema 4D both rebuild the typology of the Boolean to something a bit cleaner as you notice in the GIF you uploaded. maya Boolean dose not rebuild the typology of the new face. you get on big polygon where needs to be clean up.
Im sorry i should had been more clear on this.
Unfortunately I am are working in Pre-production with concept artists so any chance of getting a clean typology is wishfully thinking and the production dose not allow any time for clean up.
Some of this object are going to be 3d printed.
but it seems the best work flow that you may be pointing to would be to do the Boolean and do a retypology of the mesh.
im open to any other ideas and trying to avoid jumping i to other application as there already way to many! ( concept artists don't want to use maya!)
Message 4 of 12
g2m.agent
Message 5 of 12
mspeer
Hi!
Currently there is no such tool available for Maya.
Please use Help -> Speak Back -> Ideas for Maya... for this.
However you can achieve something similar by using Nurbs or by combining several nodes for Polygons.
Polygon Example (no plug-ins used):
Message 6 of 12
vfxronin
thank you @mspeer.
i think this may get us some what closers, i would love to send the feedback but thanks to the new Studio security protocols all Internet Assess have been blocked off, i'm currently writing posting using my laptop to post on the forum.
i know the Chaos group and Modo Developers guys are actively on the forum arn't the maya guys here to?
@g2m.agent thanks for point that out! i have a nothere post that ask the same about wraping mesh to a geo..
good example.
Message 7 of 12
ArcheR_BiG
Hi
Sorry, but how you do this?))
Message 8 of 12
mspeer
Hi!
Just Booleans + some sort of smoothing.
Message 9 of 12
Hi there,
Please explain this process in a bit more depth.
I am curious as to the process to which the movement/positioning is freely applied to the boolean while the command is running.
Also the smoothing process and which types of geometry are used.
If a video is posted already that might be more helpful to direct me where exactly the video is. If not maybe post a quick video of step by step instructions.
Thank you very much.
Message 10 of 12
Fovvl
I wish maya boolean would work like that, it looks cool. So far Iam using this. The work flow is not that smooth at all but it does the thing.
https://www.artstation.com/artwork/A9lOB5
https://lesterbanks.com/2019/01/maya-auto-retopology-nodes/
Message 11 of 12
vfxronin
Hey! I can't believe this subjects still alive.
well eventurly we ended up using Houdini and http://www.hard-mesh.com !
I highly subjects buying hard mesh it was amazing tool specially if your working in preproduction art department.
Message 12 of 12
forrest.brent
