Blue lines on object and not in wireframe
Message 1 of 19
I just installed Maya 2016 and am a novice. Can anyone explain to me why there are light blue/green grid-lines on my object every time I create any geometry? What is their purpose, do I need to have them and if not, how do I get rid of them?
Replies (18)
Message 2 of 19
keith112
So you're in component mode. Which you can get to by selecting F9 on you keyboard, select F8 or click the object button at the top. The orange line represents what you have selected.
Those line allow you to shape your geometry.
Here is a small section of text that will help: https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Maya/fil...
If I were you I would follow some tutorials to better understand Maya.
Best of luck
Message 3 of 19
I tried pushing F8 but it still didnt work.This is really bothering my work.Do anyone has that problem?
Message 4 of 19
keith112
Right Click on your object and select object mode
Message 5 of 19
Dude I tried that like a million times,and it doesnt work.
Message 6 of 19
Actually it worked my computer wasn't working for a little it was a broken now its fixed.
Message 7 of 19
rhoetzlein
It took me hours to solve this, but I wanted to document all the reasons for the "blue lines".
Here are the solutions:
1) Shading -> Wireframe on Shaded
2) Mesh Display -> Soften Edge (hard edges sometimes appear blue)
3) Right click -> Object Mode (blue lines in other edit modes)
4) Something in Display -> Polygons
5) Attribute Editor -> Mesh Component Display -> Display .. (several)
6) Attribute Editor -> Smooth Mesh -> Smooth Mesh Preview --- finally! my issue
Message 8 of 19
Thanks. The last one worked for me too. How the bleep did that happen?
Message 9 of 19
Probably hotkeys "1" and "2" on NumPad
Message 10 of 19
Checking off Smooth mesh preview worked for me too. Thanks!
Message 11 of 19
stony331
I know this was from 3 years ago but it helped me out #6 to the rescue!!
Message 12 of 19
damaggio
Maya basic knowledge
F8 key F9 F10 F11= facesScreenshot 2023-02-03 at 20-35-08 Maya Keyboard Shortcuts Hotkeys & Commands Guide Autodesk.png
Message 13 of 19
alexanderkaiser_artist
Community Visitor
Community Visitor
Some Heroes don't wear capes!
Message 14 of 19
camogirl757
Community Visitor
Community Visitor
Number 6 was my issue... it wouldn't let me combine the objects without smoothing things I didn't want smoothed. Thanks for the help!
Message 15 of 19
35481889
Community Visitor
Community Visitor
my god thank you so much i thought i was insane lmao
Message 16 of 19
tributo_andreanicole
LIFESAVER! HAD THE SAME ISSUE, THANK YOU SO MUCH!!
Message 17 of 19
LIFESAVER! HAD THE SAME ISSUE! THANK YOU SO MUCH!!
Message 18 of 19
Thanks for this!! : )
Message 19 of 19
jluo25
Community Visitor
Community Visitor
I got rid of the blue lines on my object by going to attributes editor > display > uncheck visibility
