Blending doesnt apply
why is the blend is not functioning? i try to transform the right side shape and apply blend with the left shape, so it suppose to be right to become like the left shape when i apply blending, but why it not changing the shape?Blend.PNG
hamsterHamster
Not possible to tell just from a screenshot alone. I'd suggest to re-do blending, just delete construction history and go into Blend Shape options and Edit>Reset, then Create.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
here is the video
hamsterHamster
Can't tell, I repeated the same steps, and it worked for me just fine. Btw, can't it be display not updating issue? Like, change the persp view angle after you set the target to 1.
,,,_°(O__O)°_,,,
mspeer
Hi!
The reason is that both shapes are exactly the same, there is nothing to change.
When you change the transform settings, like "ScaleY -1" this does not change the shape itself.
In your case you need to use Freeze Transformations (at least for "Scale").
