Black faces on imported objects
Message 1 of 15
hello
when i import a 3d obj to maya scene all the faces turn to black when using all lights , can anyone help me ??
i tried to freeze transformations , reverse normals , cleanup & break connections ...... nothing worked 😞
Replies (14)
Message 2 of 15
mspeer
Hi!
Please upload a scene-file.
Message 3 of 15
x
Message 4 of 15
mspeer
Hi!
You need to add a light to your scene!
Message 5 of 15
i dont want to add a light to the scene i need to export the obj without light
Message 6 of 15
mspeer
Hi!
1. Without any light and using "Use ALL Lights (...that are currently in the scene)" all objects are black in Viewport, you should not expect something different.
2. You don't need to export the lights in your scene if you don't want to! ???
Message 7 of 15
could you please tell me what is the difference between this obj file and the one i posted before << and why am not facing this problem with this obj ??even if i open a new scene and create a new mesh , i face the same problem ?? what is the o-mesh and G default ?
Message 8 of 15
mspeer
Hi!
There is absolutely no difference between both objects.
Does adding a light not work for you?
Please upload the Maya scene(s) + screenshots to better indicate what's your problem.
Message 9 of 15
these are the files ,,
Message 10 of 15
mspeer
Hi!
Using Mode "Use All Lights" + having not a single light will result in black objects. That's normal, because 0 (no) lights will be used
So there are 2 solution:
A) Add at least one light to your scene, or
B) Change Lighting to "Use Default Lighting"
Message 11 of 15
Mesh Display>Set to Face
I know this is old but nobody answered the question.  I import objects from Solidworks and this happens a lot.  I'm sure people check this but usually the face normals are pointing the wrong way, but even after flipping normals the object is still black.  However Going to the Mesh Display menu and selecting Set to face has always fixed this problem for me.
Message 12 of 15
Andy, I cannot begin to explain how thankful I am for your comment! Mesh Display >> Set to Face fixes all of the rendering issues I've been having. I nearly gave up completely on my project. Thank you so much! I'd gild you if this was reddit.
Peace,
Matt
Message 13 of 15
Man, I'm so glad you posted the actual solution, Andy! Super helpful. Thank you!!
Message 14 of 15
hurst.meganann
Observer
Observer
Sheeesh why you so aggressive
Message 15 of 15
luvecerviere
Fixed. Thank you, Andy.
