Align vertexes on the edges, which are not straight
adribnokhod
adribnokhod
Hi there ,
 Does any one had a tip for how we can align the vertex on that edge , isnt straight so cant use scale tool .
Leaving a screenshot to be more clear :
Many thanks in advance
damaggio
Just do it manually or cut straight with multi cut.
brentmc
As @damaggio said there is no simple way to do this in Maya but here is how yuou can do this using multi-cut and target weld.
The key to getting the right edge is to make sure the camera is aligned correctly before cutting as multi-cut is view-dependent.
Brent McPherson
Principle Software Developer
stuzzz
To keep your edges clean with a great spread, you may use this plugin.
This will save you time and make things easier. A must have in my opinion
https://vertexture.gumroad.com/l/zispread
asagAD6RJ
Observer
Observer
What's the problem for an entire team of developers to add such a feature?
Why are the years passing by, and Maya isn't producing anything useful? What are you doing there?
Why does Blender have it, but Maya doesn't?
Just add it to Maya's toolset!
Christoph_Schaedl
I would go with ZenTools.
https://apps.autodesk.com/MAYA/en/Detail/Index?id=4634919975196540444&os=Win64&appLang=en
https://linktr.ee/cg_oglu
heather_tracy
Hello @asagAD6RJ,
Did the information provided by @Christoph_Schaedl help you and answer your question?
If yes, please click on the "Accept as Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Heather | Community Manager
