Announcements
A random part showing up after deleting planes
skypurpl3ski3s
skypurpl3ski3s
Hi guys! I've been deleting some planes from a project and then a sort of bubble showed up, got bigger/smaller each plane deleted, how do I remove this bubble?
Thanks in advance!
hamsterHamster
It's likely because of indiscriminate edge deletion, something has been messed in the topology and now it has a large polygon that is connected to many edges, possibly non-manifold geo.
Either get your original mesh, or duplicate existing model to keep it as a reference.
Then, go Modeling > Mesh > Cleanup and see what options might be your case.
My go-to settings for Cleanup are:
.. however, you'd also enable FacesWithMoreThan4Sides.
After this, your mesh will be kind-of "fixed", still you will have to delete obviously wrong elements, and start with some faces, not edges. Fill holes where critical. Iterate - delete, fill, delete, fill .. cleanup.. and so on.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
