Maya LT Forum
Welcome to Autodesk’s Maya LT Forums. Share your knowledge, ask questions, and explore popular Maya LT topics.
quick rig makes maya lt crash
5 REPLIES 5
1173 Views, 5 Replies
when I use quick rig it says
Fatal Error. Attempting to save in C:/Users/(username)/AppData/Local/Temp/(username).20160517.1559.mlt maya lt bug.png
Tags (1)
5 REPLIES 5
Yeah me too! Crash!
Yeah me too! Crash!
viviane.rochon
viviane.rochon
Hi @Anonymous and @Anonymous,
I cannot reproduce the crash by following the help for Quick Rig. Could you provide me your files (zipped so that they attach to the forum), with detailed repro steps, and we will look into fixing your issue. Thank you!
Viviane
Viviane Rochon Montplaisir
Viviane
Carlos_Carpintero
Can you try something?
I see in your screenshot that you have the HIK panel open when running the Quick Rig tool.
Close the HIk panel, or switch to the Channel Box and see if that helps.  We had an issue where a bug in QT was causing Maya to hang when the Quick Rig tool was run and certain panels were open at the same time.
Let us know your results.
Carlos
Carlos
in reply to: Carlos_Carpintero
Hello!
As much as I would love to test this bug further out for you, I was on
trial and I think my trial has ended. 😞
I was testing the Maya LT to see if it can do a job for my project, but I
was not able to fully test it within the trial time due to the bug and all
that.
I am sorry..
Thanks.
Saehoon Lee
Pixellore Dev Blog
Pixellore Facebook
Subterrain: Top down survivalaction game in underground city of Mars.
Subterrain Steam Page
Hello!
that.
I am sorry..
Thanks.
Saehoon Lee
Pixellore Dev Blog
Pixellore Facebook
Hi @Anonymous and @Anonymous. I have a way to adapt to this error it is not a fix but it works.
Just after the error maya will ask your scene just click continue and save then Maya crashes and close.run Maya again click on file and click on open scene a window should popup at the bottom of the window change the files of type to Maya ASCII now locate the scene where Maya saved your scene before it crashed which is in c\users\(username)\AppData\Local\Temp and search for (username).********.****.ma
I am using Maya 2017 student
