Maya LT subscription no longer available through Steam
WesleyAdams
Autodesk Autodesk
Message 1 of 8
WesleyAdams
Autodesk Maya LT is no longer available for subscription on Steam as of April 21, 2017.  To continue using Maya LT, please visit Autodesk to subscribe.
If you have a subscription of Maya LT via Steam, you will be able to use your product until the subscription end date.
Should you require support for your Maya LT contract via Steam, please reach out to Steam support.
What is happening to Maya LT on Steam?
As of April 21, 2017, users will no longer be able to purchase new subscriptions or renew subscriptions of Maya LT through Steam. After that date, you can subscribe to Maya LT directly through Autodesk by visiting the Maya LT web page, or subscribing here.
After April 21, 2017, existing subscribers of Maya LT through Steam will continue to have access to Maya LT through Steam for the remaining duration of their subscription.
What subscription offerings are available for Maya LT through Autodesk?
Maya LT is available in a monthly, annual, and multi-year subscriptions. For more information on the pricing for the different subscription options, visit the Maya LT Subscribe page.
Do I need to re-install Maya LT when I subscribe through Autodesk?
Yes, users who formerly accessed Maya LT through a Steam subscription need to subscribe through Autodesk and re-install Maya LT.
Can I use files created in Maya LT through Steam with the regular version of Maya LT?
Yes, files created, edited, or saved in Maya LT on Steam are compatible with the regular version of Maya LT.
Is support available with a Maya LT subscription through Autodesk?
Yes, every Autodesk subscriber gets Basic Support, which provides web-based access to Autodesk technical support resources. For more information, click here.
Replies (7)
Message 2 of 8
Hi there,
I had a subscription on Steam for MayaLt until well the "no longer available announcement", i tried to look for a reseller but, i can't find one on my country "México" for Mayalt only for full Maya or 3dsmax, is there another way to get a subscription for MayaLT(2017/2018)? and if possible can the payment be made with "Paypal"?
Message 3 of 8
WesleyAdams
Hi vfxisaac,
I realize I replied on the Steam thread, but I would like to get the answer here as well, for any other people who are having the same issue.
While Autodesk is working to expand the availability of its products online in as many countries as possible, we have not managed to get to them all yet. For Mexico, as mentioned, we do have Maya and 3ds Max available. Maya LT is still currently only available through a reseller. I will be looking into this situation, but I cannot make any guarantees. For now I would recommend going through a reseller directly, and checking back regularly to see if the online purchase becomes available in the future.
Message 4 of 8
michaelkocha
I've been running into issue after issue with the latest update through Steam, so I can't say I'm all that sad to see it go..
Except that Maya LT isn't available for the latest versions of Mac OSX and won't even install on my system unless it's through Steam. When will LT support OSX 10.12.4 and are there any options for those of us who use this software professionally in the meantime?  Our studio is going to come to a standstill next month when my sub ends.
Message 5 of 8
Hi Wesley /a guy
Thanks for the replies both here and on the steam thread. Right now as you said, the best option is to get Mayalt from a reseller.
So far 2 out of 12 resellers i contacted offer Mayalt at least on Mexico, since it's not a very solicited software.
I'll leave their contact website here in case anyone from my country finds this answer:
www.darco.com.mx
And
http://cad-consultores.com.mx
Thanks again 🙂
Isaac Rivera/vfxisaac
Message 6 of 8
lapho
What problems are you running into trying to install Maya LT on Mac OS 10.12.4?
The default install returns a failure at the end of the installation process, but Maya LT is still installed.
You will need to follow these instructions here to install the missing component
https://forums.autodesk.com/t5/installation-licensing/mac-user-install-error-adsso-pkg/td-p/6937877
Lap.
Lap Ho
Maya QA
Message 7 of 8
You do not explain why you have removed it from Steam but i have my idea, the hidden reason is because on the Software > Animation & Modeling store of Steam we had the choice between two software: Blender with a score of 5/5 and thousand of positive reviews and Maya LT with a score of 2/5 with dozens of comments almost all negative about the missing feature and crashes and you weren't allowed to moderate it to delete negative comments. New users and even pro game artists could easily compare them and some would give a try to Blender after seeing the reviews.
In Maya LT Transfer Map to bake maps is deleted, there were a polycount limit for export at 10k tris now 100k (why put a limit?), the software often crashes, poor updates, bad new UI. It does much less than his free alternative even for the full version and you have chosen to remove it to hide the negative comments.
Message 8 of 8
I am inclined to think you are right. Autodesk business practice gets worse every year.
