Maya delete key doesn’t work
Hi everyone! I've been having a problem with Maya 2018.  If I select an object (3d animal animated)  and press the delete key in the graph editor or in the time slider, it no longer deletes the animal pose.
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting! 🙂 Are you noticing this behavior with all scenes/other rigs as well? Or is this behavior just tied to the single project you are working on? A good place to start troubleshooting when Maya starts acting funky is to Reset the Maya Preferences - sometimes these get corrupted and can alter the functionality of certain tools in Maya. Can you give that a shot and let me know if that improves the behavior?
Thanks for your time! I look forward to hearing from you.
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Hope you are doing well! 🙂 I just wanted to check in and see how things were going. Any luck resetting those preferences? Please let me know if you need any further assistance, I would be happy to help!
Jordan Giboney
Hi Jordan Giboney!
Thank you very much for your prompt response, it worked fine for me!
Best regards,
José
