Announcements
Just sent in 2nd crash report of the morning....
LT Ext2 SP3 Clean new iMac i7, 4gb video, 32gb ram
MayaLT freezes every 20-30 mins, if I can actually load it up in the first place.
These are low-poly mesh objects with only UVs exported to Unity, Im not making a movie.
I rarely get a maya crash report dialog so i have to manually send in a bug report.
The odds of this behavior on 2 new machines with the same symptoms are too high.
very frustrated and losing work time. I guess its time to cancel and permantly move on.
remimcgill
Hi there, as a general note crashing every 20-30 minutes is not the normal experience in Maya LT, I'm not sure exactly what is happening in your case.
Are you on Steam or the non Steam version, also what video card are you using?  You mentioned another machine, was it the same kind of setup?
Not Steam, regular install with Autodesk Subscription.
Both machines are 27" iMacs with intel Core i7's
32GB Ram, NVidia GeForce GTX 780m 4GB
I was running better until SP3, but I wasn't crash free before either.
These are simple low-poly meshes with simple UVs exported to Unity.
No animation, rigging, or anything but UVs with a Phong Shader.
Carlos_Carpintero
Hi Greg,
We suspect your problem could be related to a performance issue some people are having with SP3.  There is a workaround here on the forum, hopefully it'll help in your situation.
The post is here: http://forums.autodesk.com/t5/maya-lt-general/selection-performance-issue-with-maya-lt-2015-sp3/td-p...
If you unfamiliar with how to set Environment Variables on a Mac, there are instructions in the Maya LT 2015 help here:
http://help.autodesk.com/view/MAYALT/2015/ENU/?caas=caas/sfdcarticles/sfdcarticles/How-do-I-add-an-e...
Let us know if this helps.
Carlos
Removing all connections back to Autodesk from my Help menu seemed to have worked on my 2015 instalation.
Installing 2016 this morning, I noticed the offending feature has been removed.
So far so good
Carlos_Carpintero
Hi Greg,
I'm assuming when you say removing connections back to Autodesk, you are talking about the Customer Involvement Program and Desktop Analytics?
They are still present in 2016, but under a slightly different menu. You'll find them under "Help>Speak Back".
Before you remove yourself from them in 2016 though, we'd appreciate it if you kept yourself in both just to see if your problems have been fixed in 2016.  Then if you are still having issues, remove yourself as you did before.
If you prefer not to do this, that's ok, but it would be valuable feedback for us to have someone in the field let us know if there are still problems.  Totally up to you though.
Let us know how 2016 goes for you.
Carlos
Understand, it did help me with 2015.
I will turn it back on in 2016, as soon as i finish this task. I need to get it done
and not test things right now.
Thanks for your help
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
