Maya LT Forum
Welcome to Autodesk’s Maya LT Forums. Share your knowledge, ask questions, and explore popular Maya LT topics.
Fatal Error Attempting to save Temp .mlt
0 REPLIES 0
Message 1 of 1
475 Views, 0 Replies
Hellow,
Followed the steps on a few threads to try and trouble shoot similar sounding issue with a failed save attempt. With no luck. Non of the threads were in particular about a temp .mlt file so thought id make one in case something is different.
Ive tried updating maya
updating graphic card drives
adding MAYA_DISABLE_OPENCL=1 to my .env
Did not have an igdrclneo64.dll to delete
Tried going through crash report to find a .dll to delete, with no luck (report below)
Tried removing all the .mlt files form the temp folder
Tried running as Admin
Also got a work mate to try open file on his PC with same outcome. So probably not a driver/install issue?
Any ideas?
Maya Crash Report
Exception code: C0000005: ACCESS_VIOLATION - illegal read at address 0x00000008
Fault address: 3313DD06 in C:\Program Files\Autodesk\MayaLT2020\bin\Foundation.dll
0001:000CCD06 Logical offset (see .map file for location)
Call stack:
Module: C:\Program Files\Autodesk\MayaLT2020\bin\DependEngine.dll (-exported-)
Location: DependEngine.dllTdrawDbChangeTracker::GetTracker + 19B bytes
Decl: public: static class TdrawDbChangeTracker * __ptr64 __cdecl TdrawDbChangeTracker::GetTracker(void)
Module: C:\Program Files\Autodesk\MayaLT2020\bin\EvaluationManager.dll (-exported-)
Location: EvaluationManager.dllem::EvaluationTransparentClusterNode::~EvaluationTransparentClusterNode + 2F7 bytes
Decl: public: virtual __cdecl em::EvaluationTransparentClusterNode::~EvaluationTransparentClusterNode(void) __ptr64
Location: EvaluationManager.dllem::EvaluationGraph::evaluate + 168 bytes
Decl: public: bool __cdecl em::EvaluationGraph::evaluate(bool) __ptr64
Location: DependEngine.dllTevaluationManager::evaluate + 1B8 bytes
Decl: public: bool __cdecl TevaluationManager::evaluate(class TdgContext & __ptr64,bool) __ptr64
Location: DependEngine.dllTevaluationGraphSerializeStyle::isAllowed + 2AE bytes
Decl: public: virtual bool __cdecl TevaluationGraphSerializeStyle::isAllowed(class em::EvaluationClusterNode const & __ptr64)const __ptr64
Location: DependEngine.dllTdependGraph::setTime + F4 bytes
Decl: public: bool __cdecl TdependGraph::setTime(class TanimTime const & __ptr64,bool) __ptr64
Module: C:\Program Files\Autodesk\MayaLT2020\bin\Shared.dll (-exported-)
Location: Shared.dllTeditTracker::setCollectingEdits + 5BE bytes
Decl: public: void __cdecl TeditTracker::setCollectingEdits(bool) __ptr64
Module: C:\Program Files\Autodesk\MayaLT2020\bin\ExtensionLayer.dll (-exported-)
Location: ExtensionLayer.dllTidleAction::preDoIdleAction + F bytes
Decl: private: void __cdecl TidleAction::preDoIdleAction(class Tevent const & __ptr64) __ptr64
Location: ExtensionLayer.dllTidleAction::destroyAfterRunning + 23 bytes
Decl: public: bool __cdecl TidleAction::destroyAfterRunning(void)const __ptr64
Location: ExtensionLayer.dllTidleLicenseAction::~TidleLicenseAction + 16F bytes
Decl: public: virtual __cdecl TidleLicenseAction::~TidleLicenseAction(void) __ptr64
Location: ExtensionLayer.dllTeventHandler::doIdles + 38D bytes
Decl: public: static bool __cdecl TeventHandler::doIdles(void)
Location: ExtensionLayer.dllTeventHandler::suspendIdleEvents + 10F bytes
Decl: public: static void __cdecl TeventHandler::suspendIdleEvents(void)
Module: C:\Program Files\Autodesk\MayaLT2020\bin\Qt5Core.dll (-exported-)
Decl: public: virtual bool __cdecl QObject::event(class QEvent * __ptr64) __ptr64
Module: C:\Program Files\Autodesk\MayaLT2020\bin\Qt5Widgets.dll (-exported-)
Location: Qt5Widgets.dllQApplicationPrivate::notify_helper + 13D bytes
Decl: public: bool __cdecl QApplicationPrivate::notify_helper(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
Location: Qt5Widgets.dllQApplication::notify + 1BA7 bytes
Decl: public: virtual bool __cdecl QApplication::notify(class QObject * __ptr64,class QEvent * __ptr64) __ptr64
Location: ExtensionLayer.dllQmayaApplication::currentMousePos + 6F1 bytes
Decl: public: static class QPoint __cdecl QmayaApplication::currentMousePos(void)
Location: Qt5Core.dllQCoreApplication::notifyInternal2 + B9 bytes
Decl: private: static bool __cdecl QCoreApplication::notifyInternal2(class QObject * __ptr64,class QEvent * __ptr64)
Location: Qt5Core.dllQEventDispatcherWin32::event + EF bytes
Decl: public: virtual bool __cdecl QEventDispatcherWin32::event(class QEvent * __ptr64) __ptr64
Location: Qt5Core.dllQCoreApplicationPrivate::sendPostedEvents + 228 bytes
Decl: public: static void __cdecl QCoreApplicationPrivate::sendPostedEvents(class QObject * __ptr64,int,class QThreadData * __ptr64)
Module: C:\Program Files\Autodesk\MayaLT2020\plugins\platforms\qwindows.dll (-exported-)
Location: qwindows.dllqt_plugin_query_metadata + 1EBF bytes
Location: Qt5Core.dllQEventDispatcherWin32::processEvents + DE5 bytes
Decl: public: virtual bool __cdecl QEventDispatcherWin32::processEvents(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
Module: C:\WINDOWS\System32\USER32.dll (-exported-)
Location: Qt5Core.dllQEventDispatcherWin32::processEvents + 5DB bytes
Location: qwindows.dllqt_plugin_query_metadata + 1E99 bytes
Decl: public: int __cdecl QEventLoop::exec(class QFlags<enum QEventLoop::ProcessEventsFlag>) __ptr64
Location: Qt5Core.dllQCoreApplication::exec + 15E bytes
Decl: public: static int __cdecl QCoreApplication::exec(void)
Location: ExtensionLayer.dllTapplication::start + D8 bytes
Decl: public: void __cdecl Tapplication::start(void) __ptr64
Module: C:\Program Files\Autodesk\MayaLT2020\bin\maya.exe (-exported-)
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + E86 bytes
Decl: public: class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> & __ptr64 __cdecl TiteratorWrapperFwd<struct TscenePartitions::ConstIteratorDescriptor,class TiteratorWrapper<struct TscenePartitions::ConstIteratorDescriptor> >::operator++
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 112A7 bytes
Location: maya.exeTiteratorWrapperFwd<TscenePartitions::ConstIteratorDescriptor,TiteratorWrapper<TscenePartitions::ConstIteratorDescriptor> >::operator++ + 1030E bytes
Module: C:\WINDOWS\System32\KERNEL32.DLL (-exported-)
Module: C:\WINDOWS\SYSTEM32\ntdll.dll (-exported-)
End of stack
//crash log file name = C:\Users\GMG-01\AppData\Local\Temp\MayaCrashLog210513.1449.log
//version = 20.3.0.9401
//cut = 09/14/2020, 202009141615
//current scene = unDisclosed
//command history (most recent last):
//last tool: renderWindowSelectContextItem
//panel with focus: modelPanel4
//visible panels:
// modelPanel4 outlinerPanel1
//Memory usage:
// 22165.770 Mb Free Memory
// 20333.969 Mb Free Swap
// 815.152 Mb Current
Labels (1)
0 REPLIES 0
