Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Y-up Z-up Maya Preferences
Wouldn't it be nice to have a consistent switch or change when changing between y-up and z-up in the main settings? I encounter the same annoying procedure every now and then which should be very easy to fix.
Working for the automotive industry that is using z-up for all 3D virtual modeling purposes makes the workflow in Maya always a pain when working with characters, fluids, MASH, paint effects etc. sometimes these tools' presets are based on y-up, sometimes on z-up, sometimes they are easy to change, sometimes to change the up-axis is hidden in a particular tab not easy to find and so and so on.
I would highly appreciate a consistent choice of up-axis in the Maya Preferences, switching all related axis/ without transform/ flush transform etc.
2 Comments
daveSchoneveld
Preferences > Settings >World Coordinate System > Z
It does what you say but its pretty annoying b/c it doesn't feel tightly integrated. Maya fluids default to being rotated, among other small things.
tj.galda
Status changed to: Archived
