Select highlight
Select highlight
Selecting an object without wireframe visible. 3ds max has a nice feature to display outline around object rather than its wireframe on selection.
At the moment in maya when you disable selection highlight, you cant visualise what is selected in the viewport.
9 Comments
1006138663
This function is available and can be set in preferences
ahmed.fawaz7h8fs
Please elaborate
ahmed.fawaz7h8fs
For anyone interested this is my solution which works well for me.
F2 display objects with wireframe and shaded faces. F3 disables wireframe on selection and drops the shaded face colour to something easier to see through.
F2 hotkey:
displayPref -wsa "full";
displayColor -c -active polyFace 20;
F3 hotkey:
displayColor -c -active polyFace 01;
displayPref -wsa "none";
1006138663
//maya 2019.2
global int $CYJ_Display_Toon_Job ;
if(catchQuiet (`scriptJob -k $CYJ_Display_Toon_Job -f`) ){};
$CYJ_Display_Toon_Job = `scriptJob -e "SelectionChanged" "CYJ_Display_Toon_Do" -cu 1 -protected`;
global proc CYJ_Display_Toon_Do()
if(catchQuiet (`CYJ_Display_Toon`) ){};
global proc CYJ_Display_Toon()
string $sel[] = `ls -sl`;
string $Toon = "CYJ_toon";
if(size($sel)>0 )
if (`objExists $Toon`){delete $Toon ;}
AssignNewPfxToon;
setAttr ".creaseLines" 0;
setAttr ".intersectionLines" 1;
setAttr ".lineWidth" 2;
setAttr ".intersectionBreakAngle" 0;
setAttr ".profileColor" -type double3 1 0.75 0.3 ;
setAttr ".profileLineWidth" 0.002;
setAttr ".intersectionColor" -type double3 .5 1 1 ;
setAttr ".intersectionLineWidth" 0.002;
setAttr ".profileBreakAngle" 0;
setAttr ".screenspaceWidth" 1;
setAttr ".template" 1;
pickWalk -d up;
rename "CYJ_toon";
setAttr ".hiddenInOutliner" true;
else
delete $Toon ;
select $sel;
1006138663
I made an interesting attempt. Run the above code, maybe it's what you want. Running the second line alone will remove the program
1006138663
//maya 2020 maya 2022
string $layer = $Toon+"_Layer" ;
if(size($sel)>0 )
if (`objExists $Toon`){delete $Toon $layer;}
AssignNewPfxToon;
setAttr ".profileColor" -type double3 0.7 0.5 0.2 ;
setAttr ".intersectionColor" -type double3 .2 6 6 ;
//setAttr ".template" 1;
pickWalk -d up;
rename $Toon;
createDisplayLayer -n $layer -number 1 ;
layerEditorLayerButtonTypeChange CYJ_toon_Layer;
else
select $sel;
1006138663
where can this be set in preferences so that I get only the outline and not the wireframe on shaded?
Also , this should be the default behavior
1006138663
@Kranos_Orphydian  I didn't find this setting, so I implemented it through Mel. But the efficiency is relatively low
