Select Faces by Material
So you know how you can select objects that are assigned the same material? Make it so you can select faces in a multimaterial object that are assigned to a given material. Or make it so that Maya doesn't randomly shuffle my materials around for no ****ing reason
1 Comment
Fuchs_Leyenda
"Select objects with material" does the same thing if the object has multiple materials assigned.
