Show only
Search instead for
still waiting to see this after decades. Not closest point in mesh, not shrinkwrap, just a node (or command, ideally both) that takes a point, a vector and a target surface and returns an intersection point.
If you wanna do this through code you should lookup the `MFnMesh::closestIntersection` method. This performs a ray intersection on the attached mesh object.
