rayIntersection node
still waiting to see this after decades. Not closest point in mesh, not shrinkwrap, just a node (or command, ideally both) that takes a point, a vector and a target surface and returns an intersection point.
4 Comments
roure_osso
I'd like a light and more robust version of it, but you already have the keepOut node :]
But I agree that it would be nice to get n number of intersections, that it wouldn't be slow if the mesh where you are projecting is being deformed...
sepu6
You can do it in the graph Bifrost
roure_osso
Absolutely, but just like they recently added new math nodes, having it as a native node would make it faster computation wise.
If you wanna do this through code you should lookup the `MFnMesh::closestIntersection` method. This performs a ray intersection on the attached mesh object.
I've also made a plugin that utilizes this method which can be found here: https://github.com/bhsingleton/RayIntersection
