Maya Future
Maya Future
Hey, I was thinking... How about Autodesk start to put some effort into Maya ? I know you have many other tools... and certainly many engineers and creative minds in the "house"... So how about allocating all that brain power and start doing something here ? Alias Wavefront / Alias were incredible companies... And they had far fewer employees and resources than Autodesk and yet they did a way much better job than Autodesk. You should feel ashamed of what has been done with this tool ever since you put your hands in it, honestly. And I'm a hardcore Maya user... I loved working on this software since 2004/2005... And I came from Softimage btw. I always try to defend the tool but the desire to completely distance myself and turn entirely to Houdini is making more and more sense.
9 Comments
sean
I also come from Softimage (RIP one of the best 3D packages of all time, what a mistake it was to cancel it), and it seems like Maya is becoming more and more of an afterthought for Autodesk. Similar to the way Autodesk treated Softimage before cancelling it. 3DSMax is not doing much better, as far as progress.
Everyone I know, including most of my Studio, is switching/switched to Blender, which pains me, as I don't like Blender's way of doing things... UI, hotkeys, and on and on etc..., and MUCH prefer Maya. But the writing is on the wall, and I will probably end up switching to Blender at some point. Autodesk has lost the plot on Maya, and 3DSMax.
Actually 3DStudio R4 (yes the ancient DOS program), and then 3DSMax, is what I started my career with. 3DSMax was my only package from Release 1 to about Release 9, until I fully switched to Softimage in 2005, Then switched to Maya when Softimage was cancelled, thankfully they added a lot from Softimage to Maya at that time. But I will never go back to 3DSMax, if I can help it, as it is my least favorite package at this point, and also has stagnated, but not quite as bad as Maya has.
I absolutely love Maya, but like I said... the writing is on the wall. Unless Autodesk starts massively caring about Maya again, and competing with Blender, I am probably going to end up switching to Blender at some point.
zalnabki
Bro, I came here today to write the same thing and found your post. You're 100% correct. I'm a Maya user since Maya 3.1, and it was a big surprise for me after using 3ds Max. It was an amazing tool, and I kept using it until the last version of Maya 7, because after that Autodesk bought it, and I felt sad because I didn't see anything new. I was forced to use their version due to the very minor changes they made. So I started using their product — I believe Maya 2011 was my first attempt to use Autodesk products. For me, Maya 7 was more stable and reliable. Let me summarize a few points, please:
  1. Maya's Hypershade had amazing nodes, which at the time were unique, but unfortunately, they still use the same nodes. No change, no improvements, and even some renderers can't implement them, so they became completely useless — understood only by the software render, the only renderer Autodesk created since then.
  2. Paint Effects was also an amazing tool, but it has the same tools and parameters since it was created. They just added 'Collide with Polygon' after a long time, and that's it. Yet, it still can't be rendered by many renderers (except the software renderer). Of course, you can convert it to polygons and use it, but once you do that, you have to handle a huge polygon count, and you also have to modify the shaders significantly to prevent issues like unwanted reflections.
  3. Skeleton tools (joints, IK, muscles) are still the same as Alias Wavefront made them. Nothing new at all. Still the old methods, nothing new. They added Human IK later, but it was a joke in my opinion — completely useless unless you have a motion capture device at home.
  4. All other software has created their own render engines (e.g., Houdini). They have both CPU and GPU renderers, yet Autodesk still depends on third parties, and over that, you still have to buy their Arnold license to use it for batch rendering.
  5. I know they are concentrating more on Bifrost, but they've neglected all the other VFX tools they had (cloth, hair, rigid body). It's still the same, and even the old particle system is much, much better than nParticles. Personally, in 2018, I had to move to Houdini and use it extensively for VFX as I started to lose hope that Autodesk would do anything new in this regard.
I haven't used Blender, but I think if Autodesk doesn't do something about Maya, Blender will take over, and Maya will die. I hope this doesn't happen because old Maya users love this software — it's more of a passionate relationship rather than a practical one.
MicroCell3D
I started with Poweranimator from Alias ​​Wafefront and have known Maya since version 1.0.
The increasing stagnation in the further development of Maya is very sad and very depressing. In contrast to this is the development in the AI ​​field. The question is no longer whether to switch to another 3D software, but whether 3D software is still profitable. Time is money and unfortunately Autodesk does not understand that (see Bifrost).
If they don't build AI into Maya, then that's it... EOL
206079409
same. I think maya is better to use than 3dsmax. Although  I used initially was 3dsmax.And relatively speaking, maya is used by many companies, and blender is clearly catching up with Autodesk.With such a huge market, if Autodesk continues to do nothing, blender will surpass maya or 3dsmax will be the inevitable result. After all, Blender is completely free.
zalnabki
Bro.. Blender has exceeded Autodesk Maya way too much... It has had a node
base system for a long time.. very amazing Dynamic system..
Sculpting system very close to Zbrush.. its own render engine GPU,
unfortunately, i didn't use Blender yet but i keep watching its update.
Daniel.S.Lima
I don't think its fair to compare Maya now with Maya first releases simple because today is a thousand times more complex. It's quite difficult to any product holder keep up the updates and bug fixes over these many years without compromises.   Comparing today with the past of the software this way it only sound like a frustrated user venting out in a post.  I know this next gonna sound like I'm a fanboy but I have 20+ years professional usage with Maya, and I also came from softimage XSI and 3dsMax, but I think there is no other software that is capable to do what Maya does in a pipeline. At least yet, and probably not for a long time. I'm also a Houdini user, I know for sure Houdini wont take Maya's place when it comes to rigging and animation, modeling, simply because of the philosophy behind 100% commitment from sideFX to proceduralism.
170822353
The update mode of Maya in recent years has led to a large number of young people turning to other software, and old users will eventually grow old. When the next batch of young people dominate the market, how many people will still be using Maya? As mentioned by the brothers above, many sections have outdated functions and have not been iterated for many years. Not everyone is good at programming. If you bet on something new, the rest will be very old and look like a house with only a few places new and the rest made of wooden blocks with holes, which looks strange. In the future, we may only be able to recall the past and say that Maya was once the king.
BurkhardRammner
Funny that people still try to tell Autodesk that something is wrong with this company. You know nobody is there to hear you. You know that corporations like Autodesk have other priorities than creating cutting edge software for the producers/developers. You know that Maya will be discontinued long term and you know that blender will win. I gave up on this long time ago, but make 'funny' comments from time to time and also add some text in this 'ideas' section. And when the time has come, I will let some ai convert my Maya nodes to blender nodes, hope that there will be some option to let even convert Maya scenes and then say good by, poor Maya.
@MicroCell3D No, maya would not be "EOL" without AI features what kind of ridiculous prescription is that? Maya shouldn't have AI features, and I'm surprised it's gone this long without significant AI features since Autodesk is such a investor-focused company. It's a software for actually creating things like models and animations, if you wanna prompt pretending you are an artist while giving money to technocrats who are destroying the planet, there are already websites out there for you.
@zalnabki "Blenders sculpting system is very close to zbrush" ...LOL. 1k+ hours on blender and I can say that it's sculpting is functional, but it is absolutely nowhere close to zbrush. Blender can't handle anything more than a million verts even after the vulkan update (which destroyed AMD compatibility on it's release). Very limited brush selection and it's sculpting engine is extremely primitive. But I guess it's serviceable.
@Anonymous- this post has been edited due to Community Rules & Etiquette violation.
