(Copied from original User Voice forum)
"It would be great to have drop down menu and 3 axis buttons in the graph editor that selected only and all splines based on x, y, and z axis of translation or rotation... for example... when you open the graph editor you get all splines on a control... in the case of animating a hand you have over 15 controls with 3 splines for rotate and a few for translate and also all splines on that node like FK/IK swap and blend parents, and a lot of splines that you would never really want selected at the same time... to select the splines you want to edit you must go in and first expand the splines and ctrl click each one individually... a slow tedius process. I suggest a button/drop down menu where you can select if you want translates, rotates or all splines on a control node, and then buttons that select them all in one click."
