Fix multiprocessing support for python
Currently maya doesn't support the standard python multiprocessing module (on Windows, anyway).  It must be something to to with an interaction between what maya sets for the sys.executable and sys.prefix variables and perhaps the fact that Maya the application won't take a python file as an argument.  The upshot is that you have to do some ugly workarounds like saving temporary files and launching separate Mayapy instances to handle distributed processing.
It'd be really handy for a lot of pipeline work to be able to use vanilla python multiporocessing to paralleliize big tasks.
2 Comments
jonathan_ouellet
I second on this.  On windows it would be nice to have something line pythonw.exe but for mayapy.  It is possible to use the multiprocessing module in Maya if you set the executable in the multiprocessing module:
import sys
import multiprocessing as mp
from pathlib import Path
if not cmds.about(batch=True):
    path = Path(sys.executable).with_stem("mayapy")
    # set mayapy as process to spawn.
    mp.set_executable(str(path))
for mp.Pool() as pool:
    # do your stuff here.
This work as expected but it pop up the console. having something like pythonw which doesn't show the console will be really useful on windows.
From the python source code. pythonw use `winMain` and compile as a window application:
cpython/PC/python_uwp.cpp at main · python/cpython (github.com)
doctorpangloss
Community Visitor
Install cffi into Maya. Then, you can use this script to create a user startup script that will ensure that _posixshmem works. Set your $MAYA_SCRIPTS_DIR. Supports Darwin and Linux. This fixes the missing _posixshmem member and makes multiprocessing work correctly on Linux and Darwin (not sure on Windows). You can even run torch inside maya once this is done.
cat <<'EOF' >> "$MAYA_SCRIPTS_DIR/userSetup.py"
# --- Part 2: Fix Multiprocessing Module ---
def fix_multiprocessing():
    import importlib.util
    if importlib.util.find_spec("_posixshmem"):
        return
    import sys
    import os
    import tempfile
    import subprocess
    import shutil
    import glob
    import sysconfig
    python_include_dir = None
    for root, dirs, files in os.walk(sys.base_prefix):
        if 'pyconfig.h' in files and 'Python.h' in files:
            python_include_dir = root
            break
    build_script_source = f"""
from cffi import FFI as _FFI
import sys
_ffi = _FFI()
_ffi.cdef('''
typedef int... mode_t;
int shm_open(const char *name, int oflag, mode_t mode);
int shm_unlink(const char *name);
SOURCE = '''
#include <sys/mman.h>
#include <sys/stat.h>
#include <fcntl.h>
libraries = [] if sys.platform == 'darwin' else ['rt']
include_dirs = ['{python_include_dir}'] if python_include_dir else []
_ffi.set_source(
    "_posixshmem_cffi",
    SOURCE,
    libraries=libraries,
    include_dirs=include_dirs
if __name__ == "__main__":
    _ffi.compile()
    module_source = """
from _posixshmem_cffi import lib, ffi
import errno
import os
def shm_open(path, flags, mode=0o777):
    path_utf8 = path.encode("utf-8")
    if b'\\x00' in path_utf8:
        raise ValueError('embedded null character')
    while 1:
        fd = lib.shm_open(path_utf8, flags, mode)
        if fd < 0:
            e = ffi.errno
            if e != errno.EINTR:
                raise OSError(e, os.strerror(e))
        else:
            return fd
def shm_unlink(path):
    while 1:
        rv = lib.shm_unlink(path_utf8)
        if rv < 0:
            e = ffi.errno
        else:
            return
    with tempfile.TemporaryDirectory() as build_dir:
        build_script_path = os.path.join(build_dir, '_posixshmem_build.py')
        module_path = os.path.join(build_dir, '_posixshmem.py')
        with open(build_script_path, 'w') as f:
            f.write(build_script_source)
        with open(module_path, 'w') as f:
            f.write(module_source)
        subprocess.run(
            [sys.executable, build_script_path],
            cwd=build_dir,
            check=True
        compiled_so = glob.glob(os.path.join(build_dir, '_posixshmem_cffi*.so'))[0]
        site_packages = sysconfig.get_paths()["purelib"]
        shutil.copy(compiled_so, site_packages)
        shutil.copy(module_path, site_packages)
    import importlib
    importlib.invalidate_caches()
EOF
