edit attributes on multiple objects easily
Currently, when you select multiple objects, go to the attribute editor and change a parameter like Arnold Primary Visability, and turn it off, it only gets turned off on 1 object. It would be better if it got turned off on all of them. Currently it is possible to go into the attribute spreadsheet and change it there, but it requires many more clicks and unnessecary searching.
