Default Undo setting to be Infinite instead of 50
Having the default setting of Undo to be Infinite instead of 50 would be ideal. If memory is an issue, then a number around 200 would be more agreeable.
A new user who is learning Maya uses Undo very frequently, usually going down work flows that the user discards to return to a previous state. Not being able to because of a lack of knowledge of the default Undo setting can cause frustration and rework.
2 Comments
tj.galda
Status changed to: Accepted
We hear you.
tj.galda
Thanks for the awesome idea!  We've taken this & run with it.  Check out what we put into Maya 2020.
Keep the comments & good ideas rolling in, we're listening!
tj
