Create a single shape node of selected objects.
i need something like combine objects but want to do it with a deformer kind of thing without changing the original objects shape node or  settings.
just as we combine objects. we can turn off cast shadow , receive shadow and even self shadow of all the objects combined.
i want to turn off self shadow of 10 objects. and i want to make changes to each of the objects separately.  if there is a feature where i just add a deformer or node or setting in all the objects and they work like they are combined.
2 Comments
Hi @Anonymous - have you tried Render Setup? It allows you to easily group objects and change attributes on them in a single operation.  You can see an in-depth tutorial here: https://www.youtube.com/watch?v=VjbYQF60N2w&list=PL8hZ6hQCGHMW_4jNxt4zaYW_XzPA6y0sI
Let us know if that helps.
Cheers,
Laurence
Hi @laurence.cymet.  Thanks for the reply I will give it a shot and let you know if it fits my needs.
