I have been waiting for Maya to create 1 tool like 3ds max for over 4 years .
In 3ds max, you can select alternate polygon faces quickly through Dot Loop.
E.g. Select poly A and B then tell the tool to leave every 3 polygon faces and select the fourth.
This is very helpful in high poly models, like Gears and such.
If you are still not understanding which tool i'm talking about, you can check this link,
https://www.youtube.com/watch?v=v9_I7ZFHePg
When will this be implemented in Maya?
I know that in Maya Bonus Tools you have a similar option "Select every N-th Edge"
But its not the same, it selects both the polygons from the upper row and the bottom too.
So please add the tool like Dot Loop in Maya too. Please and Thank you.
