Only the Cube is properly 1 cm, but the others are totally different. Why?
The other primitives are not set to 1cm unless you set it in the options.
There are 25 primitives (Polygon primitives, Surface) in MAYA. (except Type,SVG,Create Polygon Tool) .
Are you going to make me set the option 25 times?
Make everything default to 1 cm.
I set option many times
surface too...
