XGen with mesh is imported from OBJ file
I am studing Xgen, when i create region map to paint, it appear a clone that symmetry x axis. This problem is only happen with mesh is imported from OBJ file, what can i do for normal?
I don't want so, i want this:
Did you delete the history of the mesh after the mirror?
Edit > Delete All by Type > History
I was delete history, freeze transform, center pivot, but issue still appear. I am using maya 2015 sp6
