XGen Painted mask can't create .ptx map. Searched Paths issues
Message 1 of 8
I have an issue when trying to save a painted mask in XGen.
I get an XGen Error which fails to create or find a folder that doesn't exist.
I've tried to manually create the folder which Maya is trying to reference.  Then it is able to save a .ptx. But I have to do this for every paintmap I make.
Here is my process on a new Maya file.
Would anyone have ideas?
Cheers
Replies (7)
Message 2 of 8
jordan.giboney
Hi @Anonymous
Thanks for posting! Could you attach another error of the script editor? Due to the size of the image I am unable to read the text in the one that was posted 🙂
Also, are you using (and setting) a Maya Project Folder? Xgen is heavily dependent on this workflow, so not using it would result in similar behavior 🙂 Lastly, are you working from a Dropbox (or similar) folder, or locally?
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 3 of 8
I'm using a project with no sync software attached. This is the setup.
Sorry, the image and format window is impossible to use here.
maya_Nct21w6Rlp.pngmaya_krt5DSIlBi.pngmaya_DyxsPc47iF.pngmaya_y1R3TltENc.pngmaya_Ysa62ptxlV.pngmaya_XvSMCeZV5y.png
Message 4 of 8
no space in path and use lambert as material
Message 5 of 8
aryanhWN8UX
Observer
Observer
I am having a similar issue.
I have a collection with 2 existing descriptions both with mask files working correctly.
When I add a 3rd description to the existing collection and try to create a new map for the mask , I get this error:
// Error: XGen: Failed to find moustache/paintmaps/mask/head_geo.ptx //
// Error: XGen: Searched path includes:
E:/myStuff/maya_projects/Anderson/xgen/collections/hair/moustache/paintmaps/mask/head_geo.ptx (Part of path doesn't exist)
C:/Users/aryanh/Documents/xgen/moustache/paintmaps/mask/head_geo.ptx (Part of path doesn't exist)
D:/Program Files/Autodesk/Maya2022/plug-ins/xgen/presets/moustache/paintmaps/mask/head_geo.ptx (Part of path doesn't exist) //
Yes I am using the project workflow and everything else seems to be pointing correctly.
Thanks.
Message 6 of 8
Walter_Sky
Community Visitor
Community Visitor
Thank you, I've changed the material on an object and forgot about it, after changing it back to lambert it fixed the issue for me.
Message 7 of 8
tvfranco
Community Visitor
Community Visitor
I've been having the same exact problem. And I don't know how to fix it.
My project is set correctly, everything else works fine. It's just the density masks that won't create a ptx. My material is set on lambert. I deleted my history and froze transformations before setting my xgen description.  Please help.
Message 8 of 8
Christoph_Schaedl
Show us the error log.
Does the object have uvs.
Is the assigned material labert1?
https://linktr.ee/cg_oglu
