Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Xgen - 3dpaint tool doesn't display the map
3 REPLIES 3
1809 Views, 3 Replies
When I try to change my density, region and all the other maps, xgen displays an orange border around my mesh and pink points. I can't see my black&white map or red&green. The brush still works so I can make changes to the map, but I can't see where I am painting so is useless.
I already tried to assign Lamber, doesn't work.
I am using Maya 2018
Please, can someone help?
Labels (1)
3 REPLIES 3
Solved: I found out that by selecting each time that I need to make a change the scalp geometry the map appears again.
lynn_zhang
Hi @Anonymous
Glad to hear you fixed the problem and thanks so much for sharing the solution! This will benefit other users in the community with the same issue.
Lynn Zhang
Another quicker way is to use isolate select, is on the viewport toolbar so is faster to use.
