Working with Revit and Cad files in MAYA
michelle4P4J9
Message 1 of 11
michelle4P4J9
Hoping someone might have some insight with something I can't seem to find an answer for. I've been using Maya for years but have recently started working with BIM models.
I'm trying to use Revit and/or CAD files in Maya in a way that makes sense. I do not have AutoCAD or Revit but have a full license for Maya. I have been given product files in both Revit and CAD formats that I'd like to be able to use for high quality renderings in Maya. Currently I'm having to rebuild or retopologize the models and there isn't a high degree of efficiency or accuracy in my current methods.
Seeing as they're all Autodesk formats I'd imagine that there'd be some effective way of doing this (other than buying Revit so that I can export it to FBX). Trial versions aren't the answer since I'll need a solution that works moving forward as well.
Thanks so much for any thoughts that can help me get this process streamlined.
Replies (10)
Message 2 of 11
hagen.deloss
Hi @michelle4P4J9
Great to hear from you on the Maya forums! I dug around on a few forum posts before I tracked down the suggestion of using a free program called pcon-planner, here is their website.
If you have access to 3ds Max, you can load up .dwg files and save them right out to .fbx or .obj as well.
Let me know if this helps!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 3 of 11
michelle4P4J9
Thanks for your suggestion. I'll give it a shot but it doesn't look like it accepts .rfa files.
Message 4 of 11
DarrenP
you will need to convert the .rfa file to an fbx file in revit
DarrenP
Message 5 of 11
michelle4P4J9
Hi Darren,
As I mentioned, I do not have Revit. Seems a little ridiculous there isn't the ability to use files created by one autodesk program in another autodesk program without buying all the programs. We have no use for Revit other than to export the files to be used in Maya so that does not solve my issue.
Message 6 of 11
DarrenP
Thats how its always been
all the autodesk software have their own native file formats & most them require you to export out to another format to be able to open in other software
DarrenP
Message 7 of 11
hagen.deloss
Hi @michelle4P4J9
I think it takes .dwg files, can you get the Revit files delivered in that format?
Hagen Deloss
Message 8 of 11
michelle4P4J9
Seems like that is the only option. Main purpose of this question was to find out how to use these files without going back to manufacturers who generated the assets years ago and may not have them anymore. Seems like there ISN'T a way to work with revit files in maya unless you have Revit or can have someone who does have Revit do it for you. That's really unfortunate.
I understand softwares have different proprietary format but since they're all owned by the same company you'd think that there'd be a little more fluidity between programs assuming most people don't buy multiple software packages. How many people really buy multiple collections of software? There should be at least an add on software that lets you convert files from one autodesk application to another without having to buy licenses for every software package.
Message 9 of 11
I've found that the following workflow provides a cleanly converted model from Revit to Maya, although it's not a free solution, which I agree should be provided by Autodesk, it does work well.
  • Buy Revit LT (monthly subscription, so minimal expense).
  • Export Revit model to DWFx file.
  • Buy PolyTrans for Maya (send an email to the seller and discuss your needs, he's really helpful).
  • Import the DWFx into Maya using PolyTrans.
This process generally produces efficient and cleanly converted models. If you want to avoid the additional expense of PolyTrans, you could export from Revit LT as FBX and go straight into Maya, but in my experience this can be hit and miss in terms of the quality and efficiency of the converted model. It would be great if the free Revit viewer allowed a simple export for these purposes but I don't think it does.
Good luck.
Message 10 of 11
hagen.deloss
@michelle4P4J9
My colleague @jose.bravoV  looked around for some ideas, and found some possibilities on the Autodesk App store:
I hope you find an answer, best of luck on your project, and let me know if I can provide any more assistance 😄
Hagen Deloss
Message 11 of 11
dgorsman
Revit and Maya have entirely different code bases and development histories.
Most advanced visualization from Autodesk CAD products is done through 3DSMAX, which has kept up with various native formats.  License wise, you'll find that most of the Collection and legacy Suite licenses include 3DSMAX along with the various design software at no additional cost.
