Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Workaround to Maya 2017 Crashing when Graph Editor open
5 REPLIES 5
965 Views, 5 Replies
I'm using the Student version of Maya 2017, which I believe means the updates/service packs are not available to me.
Maya 2017 crashes when I select a rig controller with the graph editor open.  This is listed as bug fix Maya-73305 for Update 1.
Does anyone know a workaround for this bug?  As far as I can tell, Update 1 is not available to students.  My solution has been to continue using Maya 2016.
Windows 10 64-bit (fully updated)
i7-5930k
64GB RAM
Geforce GTX 980Ti (driver updated)
Thanks much!
5 REPLIES 5
I also have the problem when i updated MAYA 2017 TO MAYA 2018.
SOMEONE PLEASE HELP!!
I'M TRYING TO TRACE THE PROBLEM USING THE OUTPUT WINDOW OF THE MAYA 2018 WHICH THE STACK TRACE SHOWS WHEN MAYA 2018 CRASHES BUT THE OUTPUT WINDOW CLOSE IMMEDIAETLY.
Here is my output window hoping that this will help.
Initialized VP2.0 renderer {
Version : 2016.11.35.12. Feature Level 5.
Adapter : Intel(R) HD Graphics Family
Vendor ID: 32902. Device ID : 2582
Driver : :10.18.10.3277.
API : DirectX V.11.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Active stereo support available : 0
GPU Memory Limit : 2183.56 MB.
CPU Memory Limit: 3780.87 MB.
MultiDraw consolidation attempted to enable, but the graphics device does not support it. MultiDraw will be disabled.
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
0: Intel(R) Corporation. Intel(R) OpenCL. OpenCL 1.2 .
Supported extensions: cl_intel_dx9_media_sharing cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics
OpenCL evaluator choosing OpenCL platform Intel(R) Corporation.
Choosing OpenCL Device Intel(R) HD Graphics 4400. Device Type: GPU Device is available.
Phoenix Fluid Dynamics ADV for Maya 2018 / V-Ray 3.x,
version 3.10.00, Build ID: 180213 from Feb 13 2018
Phoenix FD: loading C:\Program Files\Autodesk\Maya2018\phoenixfd/scripts/phxfdInit.mel...
[2018/Jul/23|00:23:00] V-Ray: V-Ray for Maya version 3.60.04 from Mar 20 2018, 20:42:24
[2018/Jul/23|00:23:00] V-Ray: V-Ray core version is 3.60.04
[2018/Jul/23|00:23:08] V-Ray: Loading plugins from "C:\Program Files\Autodesk\Maya2018\vray/vrayplugins/vray_*.dll"
[2018/Jul/23|00:23:09] V-Ray: 80 plugin(s) loaded successfully
[2018/Jul/23|00:23:09] V-Ray: Finished loading plugins.
[2018/Jul/23|00:23:10] V-Ray: Registered dynamic node vrayMultiProjection (id: 1115335/0x001104C7)
[2018/Jul/23|00:23:10] V-Ray: Registered dynamic node VRayCurvature (id: 1115347/0x001104D3)
[2018/Jul/23|00:23:10] V-Ray: Registered dynamic node VRayTriplanar (id: 1115362/0x001104E2)
[2018/Jul/23|00:23:10] V-Ray: Registered dynamic node VRaySkinMtl (id: 1115348/0x001104D4)
[2018/Jul/23|00:23:10] V-Ray: Registered dynamic node VRayPointParticleMtl (id: 1115353/0x001104D9)
[2018/Jul/23|00:23:10] V-Ray: Registered dynamic node VRayStochasticFlakesMtl (id: 1115359/0x001104DF)
[2018/Jul/23|00:23:10] V-Ray: Registered dynamic node VRayAlSurface (id: 1115350/0x001104D6)
OK.
Stack trace:
ig75icd64.dll!DrvGetLayerPaletteEntries
ig75icd64.dll!RegisterProcTableCallback
AnimUISlice.dll!TiteratorWrapperFwd<TmultiIndexDependNodeSet::ConstIteratorDescriptor,TiteratorWrapper<TmultiIndexDependNodeSet::ConstIteratorDescriptor> >::operator++
Qt5OpenGL.dll!QGLWidget::glDraw
Qt5OpenGL.dll!QGLWidget::paintEvent
Qt5Widgets.dll!QWidget::event
Qt5Widgets.dll!QApplicationPrivate::notify_helper
Qt5Widgets.dll!QApplication::notify
ExtensionLayer.dll!TwindowManager::windowPreferencesAreEnabled
Qt5Core.dll!QCoreApplication::notifyInternal2
Qt5Widgets.dll!QWidgetPrivate::drawWidget
Qt5Widgets.dll!QWidgetPrivate::repaint_sys
Qt5Widgets.dll!QSizePolicy::QSizePolicy
Qt5Gui.dll!QGuiApplicationPrivate::processExposeEvent
Qt5Gui.dll!QWindowSystemInterface::sendWindowSystemEvents
Qt5Gui.dll!QWindowSystemInterface::flushWindowSystemEvents
USER32.dll!IsThreadDesktopComposited
USER32.dll!CallWindowProcW
OPENGL32.dll!glDebugEntry
USER32.dll!RemovePropW
USER32.dll!InSendMessageEx
ntdll.dll!KiUserCallbackDispatcher
USER32.dll!InflateRect
Qt5Core.dll!QEventDispatcherWin32::processEvents
qwindows.dll!qt_plugin_query_metadata
Qt5Core.dll!QEventLoop::exec
Qt5Core.dll!QCoreApplication::exec
ExtensionLayer.dll!Tapplication::start
My particular problem was solved when I discovered I could update to the latest Maya version with a student account.  Once I updated, the problem was fixed.
You update to Maya 2018? well my problem is in maya 2018 so i contact person who can probably solve this problem but..
THANKS!!
Good luck!
