Where do I insert an AO, height and normal map from substance painter in Maya?
Samsam2019
Samsam2019
Hello all,
I am new to the texturing map workflow and I  am trying to figure out where to insert an AO, height and normal and map from substance painter to Maya. Can someone please tell me?
Also, how do you delete / remove a map, it only gives me the option to reload, edit and view?
Thank you!
jordan.giboney
Hi @Samsam2019
Thanks for posting 🙂 I actually have your web case assigned to me about this question as well! I sent an email, but here's that info again:
 Substance Painter in Maya plug-in is specifically for expediting workflows between Substance and Maya, and provides a library of photorealistic textures.
For workflow questions, I would recommend checking out the this tutorial:
Substance in Maya (video talks about bringing in textures from substance to maya)
Also, there are a ton of great resources on Allgorithmics website:
let me know if that sufficiently answers your questions, or if theres more I can help with I would be happy to chat with you more 🙂
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Samsam2019
Hello Jordan,
Thank you! I still have some more questions
