What is the name of the command under the scale tool?
velariakrah2002
velariakrah2002
Hi. What is the name of the command under the scale tool? I need to assign a hotkey to select the tool that is located there. For example, the standard G hotkey is not quite what you need.111111111111111.PNG
Parmenides
It's called 'Last Tool Used'
G (repeat last command)
Y (Last Tool used)
