hello could someone solve that issue, I am making walk cycle, whenever i set the keys on frame 1 and copy it to frame 25 and then copy to frame 13 with opposite legs, what i am looking, in frame 7 legs are not parallel, while always i get it when i put the value manually on 7th frame, i am stuck from 3 days, why it is happening, when values are same either i copy or put manually
first image- when copy paste
2nd image - when i am putting manually
Solved by mspeer. Go to Solution.
Hi @Anonymous
Thanks for posting! Could you please share your scene file with this thread? I would be happy to take a look 🙂 To attach your scene file to the thread, you will have to compress it into a .ZIP folder first.
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Hi jordan, thanks for responding 🙂
in this folder, two files are there, one is copy.mb and 2nd manually.mb, i have putted same values in both, actually i opened same file and saved it with two different name, in frame 7 u will find the difference, at frame 7 the value of both leg should be same, but when i do copy, it's not working....
i know it is some technical problem but i could not find why it is happening.... plz check it..
Hi!
In the copied version the tangents at the keys for frame "13" are set to a non default value, just change them to "Auto" in Graph Editor.
thanks allot MS peer, it is working, so this problem has been solved by you, in this solution i have an another question, always i have to do it?, bcoz when i watching any tutorial they do only copy and paste...
But main problem has been solved. thank you very much for support..👍
Hi!
After a second check the tangents of the keys you copy are set to weighted and this will be preserved.
Set them to non-weighted and it works as expected by you.
ya now i got it, thank u so much for the guidance, before ur reply i have wasted allot of time in this assignment, i am learning myself actually.
I am grateful for ur help.....
