Vray stop rendering after 10 frames. Odd !
Message 1 of 8
Hi there.
Quick question. Any idea why my render stops after 10 frames. I have a large sequence. The Maya scene file is fairly large, around 1.5 gig. Memory problem ? Well, Im using the cache geometry and btimaps options, there is no reflections/refraction, no subdivisions, etc. Dynamic memory limit is on 0. I have 125 gig of ram.
Any ideas ?!. Never happens before, I mean, many problems happens before, but not like this one, its render 10 frames and then is like, nah, I dont want to render anymore, and maya batch stops.
Working with Maya 2017 and Vray Build 3.40.04
Alvaro.
Replies (7)
Message 2 of 8
mspeer
Hi!
Did you define the frame range to be rendered in Render Settings -> Common -> Frame Range, i ask because 10 frames is the default for animation?
Message 3 of 8
Hi there. My sequence is 500 frames long. Soooo odd ! And it's not a memory problem. Double check that. No idea what is doing that. Maya error number 12123414348123 cheers.
Message 4 of 8
Nadja.Bueckmann
Hi @Anonymous,
is the issue specific to one scene or does a similar error also occur when you use a simple sample scene?
If it is related to this specific scene, would it be possible to upload the scene so that I can try to reproduce on my system?
Best, Nadja
Nadja Bueckmann
Technical Support Specialist – M&E (3ds Max, Maya)
Message 5 of 8
Hi there! I also have the same problem. After 390 frames, it stopped doing render, so i have to manually make render of each frame. The only warning i get is this >>>
// Warning: line 1: V-Ray : Num samples per thread reduced to 127858, rendering might be slower
However, i don't think that it can be a problem, but anyway.
Message 6 of 8
swaysiva
Community Visitor
Community Visitor
same problem for me also
Message 7 of 8
swaysiva
Community Visitor
Community Visitor
same problem for me also .i use new project drag all my files an render again the same issue happens only i need to render 20 frames
Message 8 of 8
ayushbakshi98
It's 2024 and I've the same issue with Maya 2025.3 and V-Ray 6. It happens randomly for me regardless of the project (simple/complex).
Well I guess we just gotta eat this heaping pile of code built upon ancient code.. 😔
